11-20-2017 02:39 PM - edited 03-08-2019 12:49 PM
I am configuring new 4500x switches. After i did vss configuration, i am not able to ping to/from the switch. Below is how it is connected to one of the core switches right now. I have tried configuring SVI or assigning IP directly on the interface, nothing seems to work.
Core-Switch# Vlan17 172.17.0.1 YES NVRAM up up interface TenGigabitEthernet1/1/5 switchport switchport mode trunk switchport trunk allowed vlan 17 TenGigabitEthernet1/1/5 is up, line protocol is up
4500# Vlan17 172.17.0.20 YES NVRAM up up interface TenGigabitEthernet2/1/32 switchport switchport mode trunk switchport trunk allowed vlan 17 TenGigabitEthernet2/1/32 is up, line protocol is up ip route 0.0.0.0 0.0.0.0 172.17.0.1 I have tried this as well. Management interface as well does not work interface TenGigabitEthernet2/1/32 ip address 172.17.0.10 255.255.0.0
Solved! Go to Solution.
01-02-2018 11:02 AM
Issue was VSS domain number which same to that of the connected switch. Changing VSS domain number resolved issue.
11-20-2017 03:49 PM
Can you post the output of "sh run" and "sh redundancy" from the vss switch?
11-27-2017 08:51 AM
Below is redundancy output and attached running config
Redundant System Information : ------------------------------ Available system uptime = 6 days, 19 hours, 26 minutes Switchovers system experienced = 0 Standby failures = 0 Last switchover reason = none Hardware Mode = Duplex Configured Redundancy Mode = Stateful Switchover Operating Redundancy Mode = Stateful Switchover Maintenance Mode = Disabled Communications = Up Current Processor Information : ------------------------------ Active Location = slot 1/1 Current Software state = ACTIVE Uptime in current state = 6 days, 19 hours, 24 minutes Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Tue 19-Jul-16 15:19 by prod BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1; Configuration register = 0x2101 Peer Processor Information : ------------------------------ Standby Location = slot 2/1 Current Software state = STANDBY HOT Uptime in current state = 6 days, 19 hours, 23 minutes Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Tue 19-Jul-16 15:19 by pro BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1; Configuration register = 0x2101
11-27-2017 09:29 AM
Can you change the config register to 0x2102, save config, reload both chassis and test again?
11-28-2017 01:28 PM
Still no luck
Redundant System Information : ------------------------------ Available system uptime = 10 minutes Switchovers system experienced = 0 Standby failures = 0 Last switchover reason = none Hardware Mode = Duplex Configured Redundancy Mode = Stateful Switchover Operating Redundancy Mode = Stateful Switchover Maintenance Mode = Disabled Communications = Up Current Processor Information : ------------------------------ Active Location = slot 1/1 Current Software state = ACTIVE Uptime in current state = 8 minutes Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Tue 19-Jul-16 15:19 by prod BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1; Configuration register = 0x2102 Peer Processor Information : ------------------------------ Standby Location = slot 2/1 Current Software state = STANDBY HOT Uptime in current state = 7 minutes Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1) Technical Support: http://www.cisco.com/techsupport Copyright (c) 1986-2016 by Cisco Systems, Inc. Compiled Tue 19-Jul-16 15:19 by pro BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1; Configuration register = 0x2102 Switch#sh cdp ne Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone, D - Remote, C - CVTA, M - Two-port Mac Relay Device ID Local Intrfce Holdtme Capability Platform Port ID Br437sw1.capilanou.ca Ten 2/1/32 130 R S I C6807-XL Ten 1/1/5 Br437sw1.capilanou.ca Fas 1 161 R S I C6807-XL Gig 1/6/3 Total cdp entries displayed : 2
interface TenGigabitEthernet2/1/32 no switchport ip address 172.17.0.10 255.255.0.0 interface TenGigabitEthernet1/1/5 no switchport ip address 172.17.0.1 255.255.0.0
01-02-2018 11:02 AM
