4500X not pingable post VSS
rajitoor55
I am configuring new 4500x switches. After i did vss configuration, i am not able to ping to/from the switch. Below is how it is connected to one of the core switches right now. I have tried configuring SVI or assigning IP directly on the interface, nothing seems to work.
Core-Switch#
Vlan17                 172.17.0.1      YES NVRAM  up                    up
interface TenGigabitEthernet1/1/5
 switchport
 switchport mode trunk
 switchport trunk allowed vlan 17
TenGigabitEthernet1/1/5 is up, line protocol is up
4500#
Vlan17                 172.17.0.20      YES NVRAM  up                    up
interface TenGigabitEthernet2/1/32
 switchport
TenGigabitEthernet2/1/32 is up, line protocol is up
ip route 0.0.0.0 0.0.0.0 172.17.0.1
I have tried this as well. Management interface as well does not work
ip address 172.17.0.10 255.255.0.0
Issue was VSS domain number which same to that of the connected switch. Changing VSS domain number resolved issue.
5 Replies 5
Reza Sharifi
Can you post the output of "sh run" and "sh redundancy" from the vss switch?
Below is redundancy output and attached running config
Redundant System Information :
       Available system uptime = 6 days, 19 hours, 26 minutes
Switchovers system experienced = 0
              Standby failures = 0
        Last switchover reason = none
                 Hardware Mode = Duplex
    Configured Redundancy Mode = Stateful Switchover
     Operating Redundancy Mode = Stateful Switchover
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 1/1
        Current Software state = ACTIVE
       Uptime in current state = 6 days, 19 hours, 24 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch  Software (cat4500e-UNIVERSALK9-M), Version 03.09.00.E RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Tue 19-Jul-16 15:19 by prod
               BOOT = bootflash:cat4500e-universalk9.SPA.03.09.00.E.152-5.E.bin,1;
        Configuration register = 0x2101
Peer Processor Information :
              Standby Location = slot 2/1
        Current Software state = STANDBY HOT
       Uptime in current state = 6 days, 19 hours, 23 minutes
Can you change the config register to 0x2102, save config, reload both chassis and test again?
Still no luck
       Available system uptime = 10 minutes
                Communications = Up
       Uptime in current state = 8 minutes
        Configuration register = 0x2102
       Uptime in current state = 7 minutes
Switch#sh cdp ne
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
Br437sw1.capilanou.ca
                 Ten 2/1/32        130             R S I  C6807-XL  Ten 1/1/5
                 Fas 1             161             R S I  C6807-XL  Gig 1/6/3
Total cdp entries displayed : 2
 no switchport
 no switchport
 ip address 172.17.0.1 255.255.0.0
