4500X VSS Password Recovery issue
Hello -
I am trying to recover the password for 4500X in VSS following the guide below:
                   http://www.cisco.com/en/US/products/hw/switches/ps4324/products_tech_note09186a0080c17598.shtml
However the config-register is setting to 0x2141 and the configuration file is not being ignored. I am unable to directly set the config-register (the command errors and says to use confreg command) - when I check the SET variables it is 0x2141 and not 0x2142.
The confreg wizard indicates the configuration file will be ignored; and I have cleared the swnum (had to use clear swnum; it would not let me use the VSS_SWITCH_NUMBER=0 command); however the configuration file is still being loaded and I am unable to reset the password.
Does anyone have any insight or suggestions?
John
Everyone's tags (2)
1 REPLY
In order to set 0x2142 you need to answer Y to:
change the boot characteristics? y/n
Then select 2 - this changes the config-register to 0x2142
Also, another difference from the guide, as mentioned above, you need to use the clear swnum command as it does not accept the VSS_SWITCH_NUMBER=0 command
Booting into password recover (no configuration) mode now.
Thanks - solved my own question
2857
