4500X + VSS + VLAN mapping = crash ?
Hello
We are deploying two 4500X in VSS.
We need to perform vlan mapping between two layer2 parts of the campus.
As soon as we bring up the trunk between the 4500X and the old network, the 4500X crashes.
If we remove the vlan mapping config, then no problem bringing up the trunk.
Below is an extract of the console log (the trunk is on the standby unit)
I am opening a TAC case right now, but wanted to ask here if anybody has experienced the same issue, or has any other idea ?
crash happens bith both versions:
cat4500e-universalk9.SPA.03.04.01.SG.151-2.SG1.bin
cat4500e-universalk9.SPA.03.05.00.E.152-1.E.bin
4500x-standby>
Exception to IOS Thread:
Frame pointer 7BE8CBB0, PC = 24D558E8
IOSD-EXT-SIGNAL: Segmentation fault(11), Process = Cat4k Mgmt HiPri
-Traceback= 1#49176b00b95a50f3145e3825de17d470  :1FBE0000+51758E8 :1FBE0000+51758E8 :1FBE0000+51806DC :1FBE0000+51843C0 :1FBE0000+69247BC :1FBE0000+69272D8 :1FBE0000+69263F8 :1FBE0000+491EB40 :1FBE0000+491F1C4 :1FBE0000+114602C :1FBE0000+1146474 :1FBE0000+1146C88
Fastpath Thread backtrace:
-Traceback= 1#49176b00b95a50f3145e3825de17d470  c:1C56F000+DF2D4 c:1C56F000+DF2B4 iosd_unix:1C954000+1877C pthread:1AFD0000+6450
Auxiliary Thread backtrace:
-Traceback= 1#49176b00b95a50f3145e3825de17d470  pthread:1AFD0000+BB8C pthread:1AFD0000+BB6C c:1C56F000+F61E4 iosd_unix:1C954000+21270 pthread:1AFD0000+6450
1 REPLY
VLAN mapping is not supported on VSS. Please see the following part of
the configuration guide:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/15.1.2/XE_340/configuration/guide/vss.html#wp1053922
Key Software Features not Supported on VSS: VLAN Translation
881
