Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
4503 sup II plus TS multicast
Hi I want to know if a 4503 with Sup II plus TS can be used for the following:
* multicast routing
* pim-sm
* msdp
* ipv6 multicast routing
The platform can not use different IOS features than IP BASE so I can not change it to advanced ip services.
What can I do? Or definetely I can not use this swith for the task?
Thank you very much
Silver
Re: 4503 sup II plus TS multicast
Sup2+ is a Layer-2 only supervisor, so it wont do any of those things.
For all of those features, you need a Sup5/Sup6 for the 4500.
Hi, I have another question, Supervisor IV does not work for this? Also, with IP BASE SSH IOS can I supprt these features or I need the ENTERPRISE SERVICES IOS?
Hi Friend,
Yes enterprise services ios will support your requirement.
Also in future you can use Feature Navigator tool. Click on search by Platform and then select you platform from drop down menu and then the release which you are looking and it will tell you the features supported in that release and festure set.
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ankur
*Pls rate all helpfull post
161
