4503 Sup II+TS Support for 100FX SFP's
Is it possible to use 100FX SFP's such as the GLC-GE-100FX= or GLC-FE-100FX on a SUPII+TS in a Catalyst 4503 Switch? I thought I could use a GLC-GE-100FX but it comes up with a unknown SFP error. I haven't tried the GLC-FE-100FX's yet. Is there any support for 100FX on this sup engine without having to add a dedicated 100FX card?
1 REPLY
Hall of Fame Super Bronze
Re: 4503 Sup II+TS Support for 100FX SFP's
It is supported with module WS-X4248-FE-SFP and IOS version 12.2(25)SG or later.
Please refer to the following documents for more info:
http://www.cisco.com/en/US/prod/collateral/modules/ps2797/ps6013/product_data_sheet0900aecd8017a0c5.html
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL632702.html
HTH,
__
Edison.
Please rate helpful posts
127
