4503 switch hangs frequently
our 4503 switch hangs very frequently. running IOS (cat4000-i9s-mz.122-20.EWA3.bin)is deferred.
please suggest if any BUGS in this related to reload the same.
I am attaching the show tech out put here.
thanks
Re: 4503 switch hangs frequently
hi,
this is urgent. i want to know the bugs cause for switch hangs / reload.
thanks
Rakesh,
I don't see anything obvious in the tech support file that indicates a problem. The IOS that you are running is quite old and it would advisable to upgrade to a newer version. Your version is deferred and there are known vulnerabilities/bugs associated with that particular release.
HTH,
Mark
200
