4503 + WS-X4013+TS have OSPF ???
Hi ALL!
I have 4503 with WS-X4013+TS and IOS
12.2(20)EWA (image name:
cat4000-i9s-mz.122-20.EWA.bin
and have possibility to configure working OSPF. All Cisco documents and resources said that it is not possible but its true. My question is following.
Is it normal ar abnormal for this hardware and software suite ?
See part of config and other additional info:
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(20)EWA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 08-Sep-04 18:41 by kellythw
Image text-base: 0x00000000, data-base: 0x01224644
ROM: 12.2(20r)EW1
Dagobah Revision 225, Swamp Revision 4
4503-m5 uptime is 48 weeks, 1 day, 55 minutes
System returned to ROM by reload
System restarted at 09:49:29 UTC Mon Dec 19 2005
System image file is "bootflash:"
cisco WS-C4503 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX092104VP
MPC8245 CPU at 267Mhz, Supervisor II+TS
Last reset from Reload
8 Virtual Ethernet/IEEE 802.3 interface(s)
20 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
router ospf 1
log-adjacency-changes
summary-address 10.32.0.0 255.255.252.0
redistribute connected metric 30 subnets route-map connected
redistribute static subnets route-map static
passive-interface Vlan105
network 192.168.50.0 0.0.0.255 area 0
network 192.168.102.140 0.0.0.0 area 0
network 192.168.102.186 0.0.0.0 area 3
default-metric 30
------------------ show module ------------------
Chassis Type : WS-C4503
Power consumed by backplane : 0 Watts
Mod Ports Card Type Model Serial No.
1 20 1000BaseX (SFP) Supervisor(active) WS-X4013+TS JAB0926003R
M MAC addresses Hw Fw Sw Status
1 0014.6a3a.1940 to 0014.6a3a.1953 1.2 12.2(20r)EW1 12.2(20)EWA Ok
4503#dir
Directory of bootflash:/
1 -rwx 12468232 Jun 27 2005 10:47:54 +00:00
27262976 bytes total (14794616 bytes free) 4503#
Re: 4503 + WS-X4013+TS have OSPF ???
Hi Friend,
No Sup2+TS doesnot support OSPF. Its a layer 2 sup engine only and supports Static routing and Rip protocol.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd8017a0c5.html
HTH,
-amit singh
Purple
The operative word here is "not supported" , the commands are there and they will bring up adjacencies with other ospf boxes because I tested in a lab situation . Don't know why they don't pull the commands if they are not supported in that platform . You can even get bgp to work in a lab enviroment on that platform . If you use a unsupported routing protocol and have a problem and look to cisco for support you know what they will tell you.
472
