4506 CatOS covert to IOS
misterc714
I currently have a 4506 CATOS, SUP-II WS-X4013. Can I covert this to IOS or must I replace the SUP card to have it running IOS?
If possible, please provide link to documents which explains how to go through the process. Thank you.
glen.grant
You cannot convert a SuppII to IOS. You must have at least a Supp II plus supervisor to have IOS . Supp II is catos only.
6 Replies 6
glen.grant
Leo Laohoo
glen.grant is right. X4013 is a CatOS Sup II and you need at least Sup II+ to run IOS. Follow this link:
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheets_list.html
Under Supervisor Engines are links that will help you navigate to which Supervisor cards you want/need.
yes thank you, i also just found this link which lists which sups can run IOS vs CatOS
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a0080094645.shtml
Thanks again,
The only models that can be converted from catos to IOS are the 6500 series.
But from what the link says I can upgrade from the SUP-II to a SUP-II Plus and that will already be running the IOS correct?
Yes. Sup-II+ is IOS while Sup-II is CatOS.
