Purple
4506 power supplies
We have a problem with a 4506 power supply we believe , it has dual 220V to each power supply and the power to each has been verified . Has anyone else seen this? This is a brand new installation . Below is the show env display, probably faulty and will have to get it rma'd. Can't say i have seen a power supply in a err-disable state.
PS2 PWR-C45-4200ACV AC 4200W err-disable good bad/off
PS2-1 220V good
PS2-2 220V good
Hall of Fame Super Bronze
Re: 4506 power supplies
What kind of power supply you have connected on PS1 ?
If it's different than PS2, then that's the reason for the err-disabled condition.
http://www.cisco.com/warp/public/473/177.html
Purple
Same one on both .
Power Fan Inline
Supply Model No Type Status Sensor Status
PS1 PWR-C45-4200ACV AC 4200W good good good
PS1-1 220V good
PS1-2 220V good
PS2-1 220V good
PS2-2 220V good
It seems you have a faulty one, then. The condition remains even after a reboot ?
Glen,
Did a research on some cases and it seems that you have a faulty power supply. Please get an RMA done for the same.
-amit singh
Purple
Thanks Amit , thats what I thought too .
1304
