4506 QoS DSCP priorities
Does a Catalyst 4506 prioritize packets according to DSCP value automatically after enabling QoS globally?
1 REPLY
Re: 4506 QoS DSCP priorities
It depends on whether you have classification policies applied and trust status on receiving port.
Here are the different scenarios:
1-Port set to trust DSCP => use DSCP from Packet.
2-Port set to trust COS => use cos to dscp map to obtain DSCP value.
3-no trust configured => use default port DSCP.
4-Traffic matches a class map => use DSCP set by policy.
Internal DSCP derived from the above are then used to place packets into the different outbound Queues.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/qos.html
Sam
135
