4506 switch access-list question
I wanted to see what access-lists we had. Does anyone know what these entries are? They don't seem to be applied to an interface.
4506_Core#sh ip access-l
Extended IP access list system-cpp-all-routers-on-subnet
10 permit ip any host 224.0.0.2
Extended IP access list system-cpp-all-systems-on-subnet
10 permit ip any host 224.0.0.1
Extended IP access list system-cpp-dhcp-cs
10 permit udp any eq bootpc any eq bootps
Extended IP access list system-cpp-dhcp-sc
10 permit udp any eq bootps any eq bootpc
Extended IP access list system-cpp-dhcp-ss
10 permit udp any eq bootps any eq bootps
Extended IP access list system-cpp-igmp
10 permit igmp any 224.0.0.0 31.255.255.255
Extended IP access list system-cpp-ip-mcast-linklocal
10 permit ip any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ospf
10 permit ospf any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-pim
10 permit pim any 224.0.0.0 0.0.0.255
Extended IP access list system-cpp-ripv2
10 permit ip any host 224.0.0.9
1 REPLY
Blue
Re: 4506 switch access-list question
Mike:
To use access lists, one first has to create them in global configuration mode and then apply them to a certain interface. That is if you want to use the access lists to filter traffic through that interface.
However, access lists are also used with route maps, QoS implementations and also in other cases. So, before deleting any access lists, make sure they are not being referenced anywhere in the config.
129
