07-04-2012 06:43 AM - edited 03-07-2019 07:36 AM
We have two 4506E interconnected with tengigabitethernet card on WS-X45-SUP6-E.
Since 2 months, we have performance problem on network.
On 4506E the CPU are in 100%, the HSRP flapping and EIGRPdown.
The 4506E version is Version 12.2(53)SG.
I don't find any issue. Have you an idea ?
Thank for your help.
07-04-2012 07:13 AM
Hello ,
What is the show log says in switch , is ports are getting flapped between the switches which is creating problem for hsrp ...
Ganeshh Iyer
07-04-2012 07:29 AM
The only log on switch :
4 12:26:02.605: %HSRP-5-STATECHANGE: Vlan206 Grp 0 state Speak -> Standby
4 12:26:02.621: %HSRP-5-STATECHANGE: Vlan55 Grp 0 state Speak -> Standby
4 12:26:02.789: %HSRP-5-STATECHANGE: Vlan4 Grp 4 state Speak -> Standby
4 12:26:02.869: %HSRP-5-STATECHANGE: Vlan6 Grp 6 state Speak -> Standby
4 12:26:02.917: %HSRP-5-STATECHANGE: Vlan14 Grp 14 state Speak -> Standby
4 12:26:03.397: %HSRP-5-STATECHANGE: Vlan100 Grp 0 state Speak -> Standby
4 12:26:03.833: %HSRP-5-STATECHANGE: Vlan172 Grp 172 state Speak -> Standby
4 12:26:04.169: %HSRP-5-STATECHANGE: Vlan202 Grp 0 state Speak -> Standby
4 14:27:26.803: %HSRP-5-STATECHANGE: Vlan14 Grp 14 state Standby -> Active
4 14:27:26.815: %HSRP-5-STATECHANGE: Vlan14 Grp 14 state Active -> Speak
4 14:27:37.956: %HSRP-5-STATECHANGE: Vlan14 Grp 14 state Speak -> Standby
07-04-2012 09:42 AM
Hello Yann,
this is only the symptom that HSRP is not working correctly
Use the following link to troubleshoot high cpu on C4500 switches
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a00804cef15.shtml
If nothing else works you have to consider the option to isolate ( disable all links to one of the switches) or to power off one of the two switches to see if the network can be restored.
if HSRP is flapping and EIGRP is down your network is not working correctly, restoring network connectivity should be your first target.
it is high time to solve this issue. The network has not been in use up to now
Hope to help
Giuseppe
07-04-2012 06:40 PM
Make sure you don't have any debug standby command enable because it could cause high CPU utilization
Thanks, RG
