4507, sup IV, Voip?
Can I push VoIP using Sup IV cards and upgrading to PoE line cards?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 4507, sup IV, Voip?
Jimmy
Without more details the simple answer is yes you can :)
Jon
Jimmy
Jon
Hall of Fame Super Bronze
You need to upgrade the power supplies as well.
HTH,
__
Edison.
We have duplicate pwr-c45-1000ac. We use 341 watts and max available is 1000. Is that not enough?
Jimmyc
You have to run the power calculator
http://www.cisco.com/go/powercalculator
HTH,
__
Edison.
There's always something...
I ran the calculator, including my projected PoE cards, and it says I will use roughly 50% of my available power. But this assumes I use 1300W PS's, which I don't. I use two 1000W PS's. I can't change the calculator to figure in my low-rent power supplies, but I can extrapolate, and take a guess that I have enough. Is that bad mojo?
149
