4507 supervisor going down after working few hours
hi
my comp is having 4507 switch it has 2 supervisor Sup V-10GE 10GE (X2), 1000BaseX (SFP). one of the sup which is in slot 1 is getting power off after working arouund 30 minutes no status power led nothing. checked the value of the Environment Variable with 'show platform environment variable' command and i found the PeerResetReason environment variable in the result with a time stamp, the output showed the following result,
PeerResetReason='12 Timer Expired 22:15:2 UTC Sun Oct 28 2007'
Also when the system is running on the secondary Supervisor Engine, i can't work in the configuration mode of the Switch. When i try to enter any Global Config mode command it gives the following error.
Config mode locked out until standby initializes
configuration mode locked out by 'PARSER Client'. Please try later
Output of the show redundancy command is;
IDAS-CORE#sh redundancy
Redundant System Information :
Available system uptime = 22 hours, 5 minutes
Switchovers system experienced = 1
Standby failures = 1
Last switchover reason = active unit failed
Hardware Mode = Duplex
Configured Redundancy Mode = Stateful Switchover
Operating Redundancy Mode = Stateful Switchover
Maintenance Mode = Disabled
Communications = Down Reason: Failure
Current Processor Information :
Active Location = slot 2
Current Software state = ACTIVE
Uptime in current state = 22 hours, 4 minutes
Image Version = Cisco IOS Software, Catalyst 4500 L3 Switch Sof
tware (cat4500-IPBASEK9-M), Version 12.2(31)SG, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 14-Mar-06 15:38 by ssearch
Configuration register = 0x2101
Peer (slot: 1) information is not available because it is in 'DISABLED' state
IDAS-CORE#exit
i dont know whtat the problem is i am sending attachment please help me out form this i will be thnak full to u
1 REPLY
Re: 4507 supervisor going down after working few hours
The module looks failed indeed.
You can try to eject and re-seat it to see if it comes back up.
Otherwise this looks like a typical DOA (Dead On Arrival). Contact your support representative for a replacement.
regards,
Leo
917
