Webcast-Catalyst9k
4507R - POE requirements
What do you need power wise if you are intending to supply POE via a 4507R ?
Do you need POE capable psu's and POE capable ethernet line cards ?
Or if you had a normal psu already installed could you just purchase a POE capable ethernet line card ?
Thanks for help
1 ACCEPTED SOLUTION
Re: 4507R - POE requirements
Hi Mark,
You need both POE capable power supplies and the POE capable ethernet line card. Both has to be there otherwise the POE will not work on 4500.
Please check the link below for more info :
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a00801f3dd9.html
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet0900aecd802109ea.html
HTH, Please rate if it does.
-amit singh
Silver
It really depends how much PoE you need. This tool should sort you out.
http://tools.cisco.com/cpc/
Cheers,
Tim.
Thanks guys
I think uf u have a POE capable line card then it gets automatically power.
Mahmood
Hi Mark,
-amit singh
Thanks Amit
179
