09-23-2008 11:56 AM - edited 03-06-2019 01:33 AM
I have a 4507R with dual 1300 watt power supplies. I want to upgrade them to the 2800 watt supplies. Can I do this hot by changing one at a time? Or do I need to power down the whole thing?
--Patrick
09-23-2008 12:18 PM
Hello Patrick,
it should be possible to do it one by one without switching the whole device
you can get some warning during the process telling that the two power supplies don't match.
For example we change damaged power supply on the fly without problem.
Hope to help
Giuseppe
09-23-2008 12:23 PM
Patrick
You can hotswap failed power supplies although i have never done it with 2 different watt power supplies.
I would recommend arranging an outage for this sort of thing just to be on the safe side.
Jon
10-08-2008 02:41 PM
I ended up powering down the whole thing and swapping power supplies. It was quick and easy.
Thanks all,
--Patrick
09-23-2008 01:22 PM
Patrick,
You can hot swap power supplies. Yes, you will want to swap out the power supplies one at a time. You will likely see error messages that the power supply wattages are mismatched. Although you are able to do this I would caution doing this after hours just in case.
HTH,
Mark
