Webcast-Catalyst9k
4510R-E SUP-6 disabled
My second sup-6 is showing a "diabled" state.  Heard several ways to fix the problem.  Which way is safer and less downtime.  I heard there may be register problem and make sure the register is set correctly and re-boot.  Heard I should pull card 6 and reboot the 4510, after reboot, insert card 6.  Anymore options?  IOS version: 12.2(52)SG2 ENTERPRISE
Jonathan,
1 ACCEPTED SOLUTION
Re: 4510R-E SUP-6 disabled
Hi Jonathan,
There is no need to reload the entire switch. The second Sup might be disable state, due to many reasons, however you should console into it and check if it's in Rommon mode. If it is, then this document would certainly help:
http://www.cisco.com/en/US/products/hw/switches/ps663/products_configuration_example09186a0080094ecf.shtml
Summary of steps from Rommon:
-     Ensure configuration register is correctly set:
rommon 1 > confreg 0x2102
-    IOS file resides in the bootflash, and should be the same image as the Primary Sup (although this should not restrict from getting the Supervisor up, however redundancy mode might be affected)
Reseating (removing and re-inserting) only is required, when we suspect the card is not seated properly in the backplane.
The above options do not require any downtime, although it's preferred to try all this during downtime, to ensure no outages due to any unexpected issues.
HTH.
Deepak
Hi Jonathan,
HTH.
Deepak
Thanks for your help. Will give it a try on Monday.
383
