4510R switch reduntant sup V in slot 2 down
arumugasamy
Dear All,
In the core switch 4510R the reduntant sup V 10GE shows down in sh module cmd. Also the following error msg in sh redundancy cmd
Peer (slot 2) is not available. It is disabled state.
What is the problem?
The redundancy cmds are
redundnacy
mode rpr
standard
swami
ankbhasi
Hi Swami,
Did you upgraded the active sup? Is it showing this error from the beginning or after something happen or you changed it is showing you this error?
Also I believe your standby sup is in rommon and is the reason it is not detecting. Can you paste me the output of "sh mod" and "sh redundancy state"?
Ankur
niranjan5
First claryby which mode are you making redudncy
RPR / SSO ?
SSO is basically for SUP Switch over for layer 2 and RPR for layer 3
so for SSO you need to configure
redundcy
more sso
auto-sync standard
I belive you in slot 2 SUP is not properly inserted need to fix it.
vishwancc
Level 3
Level 3
Hi Swami,
Give show module and check if the Image is same in both the SUP , i think it is not and since you have configured RPR the standby is disabled .
If you give show redundancy state you will RPR is not the operational mode.
Chao
Vishwa
viyuan700
Level 5
Level 5
Pls see this document if u have not referred till now,
http://www.cisco.com/en/US/products/hw/switches/ps663/products_tech_note09186a008011e6b4.shtml#standby
have uupgrade the IOS recently or tried to take out the standby sup?
