4510RE+ Does it support WS-X4648-RJ45V-E cards
          We are moving from an older 4510RE- to the newer 4510RE+ chassis. We have a WS-X4648-RJ45V-E card from the old chassis that we purchased and would like to put into the new chassis. I can no longer order this card for a 4501RE+ and I want to verify I can still use this model card in the newer 4510RE+ chassis. We plan on ordering a WS-X4748-UPOE+E card too since it provides additional POE power. I see no reason why it wouldn't be supported but I have been burned before making assumptions with Cisco equipment.
1 REPLY
Super Bronze
Re: 4510RE+ Does it support WS-X4648-RJ45V-E cards
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
I believe the chassis supports the card.  If you're changing sups or upgrading IOS, you would need to check release notes to see if the card was no longer supported with those.
104
