4900 M Switch with 3750 FiBer connectivity
We need to connect following switch over DarK Finber
4900M  with this fiber
<TR style="HEIGHT: 15pt" mcestyle="height: 15pt;">
<TD style="WIDTH: 88pt; HEIGHT: 15pt" height=20 width=117 mcestyle="width: 88pt; height: 15pt;">10GBase-LX4
 or
10GBase-LR
Other end we are having 3750-48 TS with this module :1000BaseSX SFP
Will the above fiber module are compatible ?
Br/Subhojit
Hall of Fame Super Gold
Not remotely compatible for two reasons:
1.  One end is LR and the other end is SX.  Both has to be the same, either LR-LR or SX-SX.  Not both.
2.  One end is 10 Gbps and the other is 1 Gbps.  Both end has to be same, either 10 Gbps or 1 Gbps.
Is it possible if I do the same
on 4900M : we can configure 1Gbps ( speed & duplix setting) then Is it possible to connect with 3750 Switch.
on 4900M side: we have any one of them : 10GBase-LX4,10GBase-LR ( Which end physical termination SC)
On 3750 Side: we have 1000BaseSX SFP ( switch end physical termination LC)
In between the switches we have single mode finer
In case the same is not compatible, what is the possbile workaround
Br/Subhojit
Re: 4900 M Switch with 3750 FiBer connectivity
The 4900M can support CVR-X2 module.  So if you have WS-X4908 line card, you just get one CVR-X2 module and you should be able to use the following 1Gbps SFP modules:
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
GLC-BX-D
GLC-BX-U
CWDM SFP
DWDM SFP
DWDM SFP (add.)
GLC-EX-SMD
(CPN 10-2624-01
or later only)
GLC-ZX-SMD
HI Leo,
Many thanks for your support
Can you pls share the relevant cisoc docuemntation (SFP card compatibility matrix, for my knowledge only
Also, Pls provide the below info
1) If I insert SX SFP module on 4900M, will it support single model finer termination.
2) If I insert any LR module in 3750, Will it work, if yes -- pls share the respective SFP details
Br/Subhojit
Cisco Small Form-Factor Pluggable (SFP) Transceiver Modules Maintenance and Troubleshooting
I have already answered this question, twice.
Hi Leo,
Small query,
1) As for 4900M, Lr module support only MMF & LX module support only SMF,
for 3750G switch , pls confirm the below
SX SFP support SMF & LX SFP support MMF, or they are supporting for means SMF & MMF
2) Fiber conditioning patch cord use - in this Industry recomended or any performace degradation can observed
Br/Subhojit
Seriously, you need to read and understand my responses.  I have already responded to similar questions, TWICE.
for 3750G switch , pls confirm the below SX SFP support SMF & LX SFP support MMF, or they are supporting for means SMF & MMF
Same as above.  Similar line of question has been answered TWICE.
If you are using LX laser modules, patch conditioning cable is recommended.
Hi Leo,
Pls find the inventory from 4900M Switch, It seems we are having CVR-X2 Card.
sh module
Chassis Type : WS-C4900M
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     8  4900M 10GE (X2)                        WS-C4900M          JAE154501DW
2    20  10/100/1000BaseT (RJ45)                WS-X4920-GB-RJ45   JAE14090382
3    24  10GE (X2), 1000BaseX (SFP)             WS-X4908-10GE      JAE14090NAY
So, as you mentioned in earlier Post, WS-X4908-10GE ( we can use LR or LX4 based on our requirement) is supporting CVR-X2 Module.
So we have 2 option as per my understanding, Pls correct me If I am wrong
For SMF case,
1) So on 4900M, We can use LR connector & on 3750G end we can use GLC-LH-SM Type SFP with 1G Speed.
For MMF Case,
2) So on 4900M, We can use LX4 connector & on 3750G end we can use GLC-SX-MM Type SFP with 1G Speed
Br/Subhojit
Subhojit,
For the THIRD TIME, this is not going to work.
As long as BOTH SIDES use GLC-LH-SM, this will work.
Thanks Leo for your time.
1 last query:
Can you pls share the P/N of the 1G SFP compatible with 4900M ( CVR -X2 Module)
Br/Subhojit
I have already given you a list of SFP compatible with 4900M CVR-X2.  All you need to do is scroll up and read my posts.
Sorry for wrong question, What I try to mean -- As per your earlier Post, Below SFP are compatible.
GLC-T (1000BASE-T)
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
Pls share the CVR-X2 module part-code(blank module) where the above SFP will fit, so that I can insert the X2 module in 4900M
As the above SFP normally used in 3750 Series switch.
Br/Subhojit
Good grief!
I've already provided the part code (including the data sheet).
Br/Subhojit
Hi Leo,
We have tried with CVR-X2 connector with the 1G SFP, but the same is not detecting.
Any dependency with IOS.
Present IOS is : cat4500-ipbasek9-mz.122-50.SG3.bin
Br/Subhojit
681
