Community Member
4900M Port Configuration
Are you able to do a switchport trunk encapsulation dot1q command under a port. I am not seeing it.
Re: 4900M Port Configuration
AFAIK 4900 series switches supports the command, in which ios version you are trying this commmand ?
regds
Community Member
I don't think it supports anything but dot1q so it's on by default.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps6021/ps9310/Data_Sheet_Cat_4900M.html
interface GigabitEthernet2/9
switchport mode trunk
interface GigabitEthernet2/10
interface GigabitEthernet2/11
switchport access vlan 172
switchport mode access
4900M#show ver
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500e-IPBASEK9-M), Version 12.2(40)XO, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Tue 22-Jan-08 21:39 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11D8D84C
ROM: 12.2(44r)SG
Darkside Revision 0, Jawa Revision 11, Tatooine Revision 140, Forerunner Revision 1.71
4900M uptime is 7 weeks, 19 hours, 4 minutes
System image file is "bootflash:cat4500e-ipbasek9-mz.122-40.XO.bin"
4900M#show inter trunk
Port Mode Encapsulation Status Native vlan
Gi2/9 on 802.1q trunking 1
Port Vlans allowed on trunk
Gi2/9 1-4094
Port Vlans allowed and active in management domain
Gi2/9 1,172
Port Vlans in spanning tree forwarding state and not pruned
Gi2/9 1,172
4900M#
Community Member
Hi All
Can anyone answer the following questions
Can the 4900 Merge traffic from 4 10ge VLAN ports before throwing away one of the VLAN tags, then merge it with 4 10ge none VLAN traffic before piping it out to one or more 10ge interfaces?
David
847
