4900M Twingig Converter Module / SFP
Hi there,
I am little confused with all these SFP types.
Can I use GLC-LH-SM, GLC-LH-SMD and SFP-GE-L with Twingig converter module? When I used Cisco configuration tool, the only option is GLC-LH-SMD for 1000BASE-LX.
2 ACCEPTED SOLUTIONS
VIP Super Bronze
Here are all the supported Optics with Twingig converter
GLC-T
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
Also see table-8 in this link:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6981.html
Hall of Fame Super Gold
End-of-Sale and End-of-Life Announcement for the Select Cisco Gigabit Ethernet SFP Modules
Any SFP that ends with a "D" means it supports Digital Optical Monitoring (DOM).
SFP-GE-L is similar to GLC-LH/LX but is not supported on the 4900M. or TwinGig converter.
VIP Super Bronze
GLC-T
GLC-SX-MM
GLC-LH-SM
GLC-ZX-SM
GLC-SX-MMD
GLC-LH-SMD
Thanks, just curious what is difference between SFP-GE-L and GLC-LH-SMD?
Bronze
You need also consider that base 4900M chassis does not support TwinGig converters.
1009
