06-28-2012 01:02 PM - edited 03-07-2019 07:31 AM
Just received one of these switches. My understanding is the 10G ports on the
WS-X4908-10G-RJ45 should be able to connect to a 1 G port on another switch.
However I can not get this to happpen. Using either a crossover or straight through cable.
06-28-2012 01:15 PM
06-28-2012 03:22 PM
I'm with Reza.
The logic behind the reason (why this line card will only run on 10Gbps) is: WHY?
Why purchase a very expensive line card and let it run 1 Gbps when there are more affordable line cards with much, much more density.
06-29-2012 07:47 AM
The reason is why we bought the switch for our ap server to communicate with our database server. But we dont need it on our main network which is only 1 gig. We really dont need all the ports of the 20 port gig card.
06-29-2012 01:19 PM
And by the way it is possible
the command is
hw-module module 2 port-group 1 select gigabitethernet
this sets port 2/1 and port 2/2 to gig
they are both set due to the way the ASIC in the card works
yes it works
