4948-10GE
Can some one please confirm that the 4948-10GE switch comes with adapters that allow you to use the 2 x 10gb ports as 4 x 1gb with lc gbics
Silver
Re: 4948-10GE
nope:
http://www.cisco.com/en/US/docs/switches/lan/catalyst4900/4948-10ge/05modcfg.html
"The Cisco 4948-10GE switch has two ports that can be configured with modules with SC connectors, as shown in Figure 4-1. The following module types are supported:
?LR
?Other types are ro be announced soon "
the question is: "why use 4 links 1Gb each instead of 2 links 10Gb each?"
Andrea
Re: 4948-10GE
We are planning on slowly migrating over to 10gb, maybe after a year or so.
Re: 4948-10GE
The carrier module I believe you are thinking about is like the new E-Series 3750's. That carrier isn't available for the 4948, it's 10Gig only. You may want to check out your switch there is a bug that has been found in the early serial numbers where it will go to RMON after a reboot. The fix is to swap it out, I have 40 of them going back once I figure out how to schedule the downtimes....
116
