4948 2x10G Etherchannel
gerald.suiza
I would just like to confirm if it is possible to create a 2x10G etherchannel on a 4948.
Giuseppe Larosa
Hello Gerald,
yes it is possible I have seen several C4948 connected wih 2 X10GE etherchannel to a pair of Nexus 7010.
Hope to help
Giuseppe
Giuseppe Larosa
Hello Gerald,
Hope to help
Giuseppe
hi,
Thanks for the fast reply..would you know if there is any additional config or is it just the normal etherchannel config for 10G?
Hello Gerald,
standard configuration I recommend to use LACP: it is standards based and allows for detection of errors in cabling.
Hope to help
Giuseppe
thanks!
