4Mb memory 2509 which IOS
We have an 2509 with only 4 MB of RAM. I tried with the IOS upgrade planner on Cisco web to find a IOS image without luck. Is there a tool out there where you can use the RAM memory as input
thanks,
ted
Bronze
Re: 4Mb memory 2509 which IOS
You can try with Cisco's Software Advisor. Even this tool does not take RAM as input, but in the results page it displays the minimum RAM required. You can short list the image there.
1) Go to this URL http://www.cisco.com/en/US/support/tsd_most_requested_tools.html
2) Choose the Sofware Advisor tool. You should be a registered user for accessing the tool.
Purple
You are going to have to try and find an old 11.X code to run , 12.0 and above requires at least 6 meg to run .
119
