Webcast-Catalyst9k
5548 versus 5672
Can some provide the major difference in the Nexus 5548 vs 5672.  We are building a scaleable 1000K VDI infrastructure using Cisco B300, Nimble CS240G storage.  We are not using the 2960s switches as originally suggested in the diagram below.
Other than the speed (1.4 TBps vs 960 Gbps) and # of ports, should be invest in the 5672?
Sapan
VDI scaleup
1 REPLY
VIP Super Bronze
Hi,If you have the budget, I
If you have the budget, I would invest in 5600 series, as it gives you 10 or 40G uplinks.
Also, layer-3 daughter card is already built in to it in case you need it.
627
