ā04-27-2012 11:52 AM - edited ā03-07-2019 06:22 AM
just a simple question. Is it possible to use a nexus 5548 UP switch as a layer 3 router between different vlans on the switch without the layer 3 card ? Or is there no 5548 as a router with the layer 3 card ?
ā04-28-2012 12:28 PM
If you want to use the 5500 series as routers, you need the layer-3 daughter card
see figure-4 in this link:
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
ā05-04-2012 07:03 AM
Just to add more details to Reza's post:
you can configure SVI's and even routing protocols (ospf, bgp) on nexus 55XX without having L3 card - commands for that will be available in CLI, but performance will be very weak and nexus won't perform routing for most of the destinations even to localy connected ones.
So as Reza said you will need L3 module for L3 operations and base license which is free.
LAN_BASE_SERVICES_PKG
Hope that answer yur questions.
Alex
