Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
5609 redundent sup720
Hi,,,
The problem that we had is with the redundant supervisor engine sup720 it is always boot to the rommon mode, we had copy the same ios (s72033-ps-mz.122-17d.SXB1.bin) from the active sup720 to the disk0 and copied it to standby sup720 and when we issue the following command
Rommon>boot disk0: s72033-ps-mz.122-17d.SXB1.bin it boots normally and the switch is working fine, we copy the ios to the sup-bootflash in the redundant sup720 and we issue
Router(config)boot system sup-bootflash: s72033-ps-mz.122-17d.SXB1.bin
Router#copy run start
Router#reload
The switch boots in rommon mode again.
Please find attached switch RAR file including running-config, snap shoot from both sup720 and the crashfile.
Re: 5609 redundent sup720
We would like to check the config-register settings on the standby Sup engine which is creating the problem. Would you be able to make the Standby Sup as an active one and then try checking the Sup's config register. Once you are on the standby sup after making active with console, Do the following:
remote login switch
show version
This should tell us the config register settings on the sup side. Try chanhing to 0x2102, if its other than 0x2102.
HTH,Please rate if it does.
-amit singh
Hi Amit
the config register in the standby sup is set to 0x2102 and i already posting the sup720 needed config and crashfiles.
I can made standby sup720 active only when i boot from the disk0:
rommon 3 > boot disk0:s72033-ps-mz.122-17d.SXB1.bin
then i copied the ios to sup-bbotflash
Router#reload
The sup720 boot in rommon again.
regards
Hi Friend,
Can you manually boot again and set the boot path as "boot system flash sup-bootflash: s72033-ps-mz.122-17d.SXB1.bin" and then wr mem and then try reload again.
Also I believe you must be having image on your sup-bootflash:
Ankur
425
