6000 switch MSFC in Rommon mode
This switch is using the CATOS for layer 2 and IOS for Layer 3, So currently the CATOS is running well but the Layer 3 in the ROMMON, pls refer to below:
rommon 1 > boot sup-slot0:c6msfc-dsv-mz.121-27b.E1.bin
an alternate boot helper program is not specified
(monitor variable "BOOTLDR" is not set)
and unable to determine first file in bootflash
loadprog: error - on file open
boot: cannot load "sup-slot0:c6msfc-dsv-mz.121-27b.E1.bin"
Is it Have any idea to boot it up.
-Gilbert
Blue
Re: 6000 switch MSFC in Rommon mode
Try the "boot slot0:c6msfc-dsv-mz.121-27b.E1.bin" command.
(dont use sup-slot0:, just slot0:)
Also, when you get the MSFC running, goto global config mode and enter the "boot system flash slot0:c6msfc-dsv-mz.121-27b.E1.bin" command to set the boot file to load automatically.
Purple
I believe the old Supervisor 1's need to have a bootloader image loaded into msfc bootflash with the corresponding boot statement to boot up correctly . Go out and get the bootloader image that goes with this version and load it into "MSFC" bootflash and set your boot statement to reflect this , "boot bootldr bootflash: , then write mem. Also your first boot statement was correct pointing sup-slot0: .
I had tried the command which suggested but it come out the message as below:
rommon 2 > boot slot0:c6msfc-dsv-mz.121-27b.E1.bin
boot: cannot load "slot0:c6msfc-dsv-mz.121-27b.E1.bin"
rommon 3 >
pls advise
-Gilbert
Is it any 1 can help on this issue.
Much Appreciate for the help.
-Gilbert
Anybody help on this issue.
Thanks a lot
-Gilbert
167
