Community Member
6148 and oversubscription
When would over subscription actually become an issue that I can show management via a show command on the switch.
When I look at the cards I see only output drops on the occupied ports. Utilization is low and there are no other errors yet users still complain the net is slow.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: 6148 and oversubscription
Hello Mark,
I would say that the output drops on the port are already meaningful because:
each output drop frame is simply lost, the IP packet carried inside the ethernet frame can be part of a TCP conversation.
So a dropped packet is detected at the TCP level and this requires retransmission.
when the probability of drop is not so small all user TCP sessions are affected and users complain of resulting slowness = low TCP goodput
This is the kind of reasoning you should offer to the management, if users complain of slowness it is a problem this is the point regardless that there is no red alarm on the module or other direct indicator.
I've found a useful link that can help you in explaining the issue when servers are involved (it should be in your case if I remember correctly)
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a00801751d7.shtml#ASIC
it provides a show command
show counters           interface gigabitEthernet | include           qos3Outlost
and a workaround to reduce the effects of oversubscription (to be tested  so I would say that it can be not effective I wouldn't mention this to management)
Hope to help
Giuseppe
1 REPLY
Hello Mark,
Hope to help
Giuseppe
1536
