01-16-2010 04:20 AM - edited 03-06-2019 09:19 AM
Dear All
I just connected one of 6500 and tried to boot , but it gave me the below message and it stucked there .
how much time will take a 6500 to boot ? Is it becase of falsh ?
System Bootstrap, Version 8.5(2)
Copyright (c) 1994-2007 by cisco Systems, Inc.
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
Autoboot executing command: "boot disk1:s72033-ipservicesk9_wan-mz.122-18.SXF13.
bin"
Loading image, please wait ...
Initializing ATA monitor library...
haris
01-16-2010 04:35 AM
Hello Haris,
following document can be of help
http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008015bfa1.shtml
I'm little confused by the lines you have attached:
this looks like old similar to CatOS, I've checked on one of my devices
this is a native IOS image
Have you moved the flash from another device running native IOS?
I wonder if this specific C6500 is to be prepared for native IOS that is if it is expecting to work in hybrid mode.
If so you may need to perform the conversion procedure from CATos to IOS before the system can boot a native IOS image
Hope to help
Giuseppe
01-16-2010 07:39 AM
Hello Haris
Normally cat6500 with sup 32 or 720 it will take 20 to 25 mins to boot
At this point 5 to 8 min to boot to next level
regards
krishna kumar
01-16-2010 08:03 AM
01-16-2010 08:20 AM
Pl download the same IOS from cisco software download site and reload the switch, if still the problem persit could be hardware issue
regards
krishna kumar
01-17-2010 02:12 AM
Dear Giuseppe ,
Do u have any docs for the conversion procedure from CATos to IOS before the system can boot a native IOS image . I want to boot from natiove IOS image
Haris
01-16-2010 01:57 PM
I hope you are doing great,
I just review your crash information and I think you can be hitting this bug:
You may like to upgrate your IOS version in order to avoid the problem.
If you have any questions please let me know it.
01-17-2010 01:27 AM
You can download this file and reboot this switch
Hope this will solve your prob
s72033-ipservicesk9-mz.122-18.SXF17.bin
regards
krishna kumar
01-17-2010 02:09 AM
Dears ,
I downloaded the image s72033-adventerprisek9_wan-vz.122-33.SXH6.bin and put it in my disk1: and then i tried booting from the rommon mode to boot disk1:s72033-adventerprisek9_wan-vz.122-33.SXH6.bin and it succeeded .
But there is still something wrong . I'm getting the below error on my show version and also when i reboot it's going to rommon eenthough i configured "boot system disk1:s72033-adventerprisek9_wan-vz.122-33.SXH6.bin" .
"Patching is not available since the system is not running from an installed imag
e. To install please use the "install file" command "
Haris
01-17-2010 02:31 AM
Pl check the show run configuration contain any old boot image configuration
add this commad
conf t
and save the config also verify the next boot image
show bootvar
or
show boot
for 2nd error
you may downloaded modular image version
this is not a prob
regards
krishna kumar
Haris
01-17-2010 02:46 AM
Hello Haris,
those messages are related to the fact that you have moved to modular IOS and are only warnings.
Be aware that modular IOS for C6500 is affected by some bugs as reported by other colleagues in the forums.
so unless you strictly need modular IOS for some feature, it may be wise to use a standard IOS image. You should be able to download it from sw center.
About conversion from CatOS to IOS you need to follow the procedure according to your supervisor (steps depend on supervisor type) :
http://www.cisco.com/en/US/products/hw/switches/ps708/products_tech_note09186a008015bfa6.shtml
Hope to help
Giuseppe
01-20-2010 01:08 AM
Dear All ,
Thanks for your help ...My problem is solved now ...
I changed the IOS to s72033-ipservicesk9_wan-mz.122-18.SXF13.bin and all errors gone .
Basically I have problem with Slot seating and IOS .Thanks for your valuable inputs
Haris
