6500 CATOS QoS ACL configuration
I'd like to mark DSCP on every user port based on tcp and udp port ranges:
1. mark udp range 16384 32767 to dscp 46/EF
2. mark tcp range 2000 to 2002 and 2427 to 2428 to dscp 24
Can qos acl support multiple entries?
can I configure:
set qos enable
set qos cos-dscp-map 0 8 16 24 32 46 48 56
set qos acl IPT dscp 46 udp any any range 16384 32767
set qos acl IPT dscp 24 tcp any any range 2000 2002
set qos acl IPT dscp 24 tcp any any range 2427 2428
commit qos acl IPT
set qos acl map IPT 1/1-48
set qos acl map IPT 2/1-48
The goal is to mark DSCP values based on application attributes. In the future, acl can expand to mark dscp for Tanberg, VT-Advantage, etc... on other ports
but in CATOS, can I configure ACL with multiple lines? I check CCO and there is no example
Silver
Re: 6500 CATOS QoS ACL configuration
The following documents have more information:
QoS Classification and Marking on Catalyst 6500/6000 Series Switches Running CatOS Software - http://www.cisco.com/en/US/products/hw/switches/ps700/products_tech_note09186a008014f8a8.shtml
set qos acl ip -
http://www.cisco.com/en/US/products/hw/switches/ps708/products_command_reference_chapter09186a00802dec70.html#wp1026940
I have read all these. They don't answer my question at all
"can I configure ACL with multiple lines"?
732
