6500 CatOS - QoS Statistics
When I run the command below I get no statistics. Can anyone tell me if I need to configure the switch to enable this
(enable) sh qos statistics 5/1
Tx port type of port 5/1 : 1p2q2t
Q3T1 statistics are included in Q2T2.
Q# Threshold# Packets Average Packet Peak Packet
dropped (pkts) drop rate (pps) drop rate (pps)
1 1 0 0 0
1 2 0 0 0
2 1 0 0 0
2 2 0 0 0
Rx port type of port 5/1 : 1p1q4t
Q2T1 statistics are included in Q1T4.
1 1 0 0 0
1 2 0 0 0
1 3 0 0 0
1 4 0 0 0
Hall of Fame Super Silver
Re: 6500 CatOS - QoS Statistics
Hello Anthony,
just a basic check
is mls qos enabled on the device ?
it should be something like
set mls qos
Hope to help
Giuseppe
Hi Guiseppe
I have 'set qos enable'
I can see not set mls qos
here is the output from sh mls
(enable) show mls
Total packets switched = 312007053990
Total bytes switched = 248213177932270
Total routes = 527
Total number of Netflow entries = 2
IP statistics flows aging time = 16 seconds
Long-duration flows aging time = 320 seconds
IP statistics flows fast aging time = 0 seconds, packet threshold = 0
IP Current flow mask for NDE is Null flow
Netflow Per Interface disabled
Netflow Data Export version: 7
Netflow Data Export disabled
Netflow Data Export port/host is not configured.
Secondary Netflow Data Export port/host is not configured.
Total packets exported = 0
Total packets exported to secondary = 0
Total NDE collectors configured = 0
Destination Ifindex export is enabled
Source Ifindex export is enabled
Netflow Per Vlan is disabled on vlan(s) 1-2,100-101,108,110,112,114,116,118,120,122,124,126,128,130,132,134,136,138,140,
230-233,235,237-238,240-252,1006-1014,1016.
Cannot get netflow per vlan status information of vlan(s) 1002-1005.
Rate limiting is turned off, packets are bridged to router
Load balancing hash is based on source and destination IP addresses and universal id 48e100aa
Per-prefix Stats for ALL FIB entries is Enabled
OPP-Comms-BlockA> (enable) set mls ?
agingtime Set agingtime for MLS cache entry
cef MLS CEF commands
exclude Set MLS excluded protocol ports
flow Set minimum flow mask
nde Configure Netflow Data Export
netflow-entry-create Enable/Disable creation of flows per vlan
netflow-per-interface Enable/Disable Netflow Per Interface
rate Set rate limiting value in pps (0 to disable)
statistics Add protocols to protocol statistics list
verify Set packet parsing verification
Anthony
Hello Anthony,
that is fine I probably mixed different commands in my mind (with IOS)
if we look at the text in the show
my understanding is that you will see non zero stats only when some packets will be dropped in any port queue.
Have you overloaded the port with traffic ?
Hope to help
Giuseppe
Hi Giuseppe,
This a live switch so I cant overload the port.
But if I dont see anything on the port stats I'll assume its okay.
Anthony
266
