03-07-2008 12:29 AM - edited 03-05-2019 09:36 PM
The stupid manual does not give units for the interval used by a probe...does anyone know if these units are seconds or minutes?
Solved! Go to Solution.
03-07-2008 12:49 AM
Okay, i haven't got 4.1.1 on any of our CSM's but with the CSM and the CSM-S versions i have used it has always been in seconds.
Quickest way to test would be to just sniff the traffic on one of your servers to see how often the probe turns up.
Sorry i can't be more help.
Jon
03-07-2008 12:35 AM
Hi Dave
Presumably you are referring to the Content Switch Module ?. It is in seconds - see attached link
Jon
03-07-2008 12:47 AM
I should have said we are running software 4.1.1
In that manual the units are missing!
Has anyone acually run a test to confirm the units are seconds in v4.1.1?
03-07-2008 12:49 AM
Jon
03-07-2008 01:01 AM
As far as I'm aware probes have always been in seconds.
Also, the 4.1.1 manual does say seconds, here:
Andrew.
