6500 CSM
The stupid manual does not give units for the interval used by a probe...does anyone know if these units are seconds or minutes?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: 6500 CSM
Okay, i haven't got 4.1.1 on any of our CSM's but with the CSM and the CSM-S versions i have used it has always been in seconds.
Quickest way to test would be to just sniff the traffic on one of your servers to see how often the probe turns up.
Sorry i can't be more help.
Jon
Re: 6500 CSM
Hi Dave
Presumably you are referring to the Content Switch Module ?. It is in seconds - see attached link
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/4.2.x/configuration/guide/helthmon.html#wp1025018
Jon
Re: 6500 CSM
I should have said we are running software 4.1.1
In that manual the units are missing!
Has anyone acually run a test to confirm the units are seconds in v4.1.1?
Re: 6500 CSM
Jon
Re: 6500 CSM
As far as I'm aware probes have always been in seconds.
Also, the 4.1.1 manual does say seconds, here:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/csm/4.1.x/4.1.1/configuration/guide/helthmon.html#wp1025018
Andrew.
222
