6500-E with SUP720 compatibility with 10g module
I have 6509-E chasis with supervisor VS-S720-10G.
I need to add a new WS-X6708-10G-3C= module to this same chasis.
As per the cisco datasheet both the cards and the supervisor are compatible, just need to confirm this.
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
IT should work.  The Sup2T will "downgrade" itself to the same level as your line card.
WS-X6708-10G-3C
Should be compatible.
Be aware that if you plan to upgrade your Supervisor card in the future to Sup2T, then you can't use this card.
Can you also post the output to the command "sh module".
is this card not completable with the SUP 2t ??
i have another chasis with SUP2T and i am ordering the same for that as well.
WS-X6708-10G-3C will never be compatible with Sup2T.  The Sup2T has DFC4/PFC4 and the card has DFC3/PFC3 card which cannot be upgraded.
my supervisor is VS-SUP2T-10G with XL but i am ordering the module WS-X6816-10G-2T which is without the XL.
will there be any compatability issue ?
251
