05-16-2008 12:37 AM - edited 03-05-2019 11:01 PM
Hi all,
I'm experiencing issue with one 6500 Layer 2 CatOs.
When display "Sh vlan" command, I see a strange port behaviour. Look at the attachment....unbelievable...did anyone know what is the possible cause of this strange behaviour?
Thanx in advance for any suggestions...
05-16-2008 01:20 AM
hello, i gone through ur attachment posted bt im unable to point out what is ur real problem. can u plz specify n why u gave the extra commands like sh mod n sh ver.
05-16-2008 01:31 AM
The problem is port 7/44 which is showing in all the vlans even though it has been allocated only to vlan 1.
To the OP, can you adminstratively shut the port down to see if that makes any difference. I have not seen this before.
Jon
05-16-2008 01:39 AM
I just tried to disable port but no change occured. I tried to create a new vlan and then assign it to the port, but in this case also, no changes occured.
05-16-2008 01:37 AM
Just for let you see what kind of module are installed.
My problem is that when you enter "sh vlan" command, the port 7/44 is inserted in every vlan even though it is assigned only to Default Vlan. I don't know if it's a real problem, but this is really strange.
05-16-2008 01:56 AM
but it's not in EVERY VLAN. Its not in 10or 11, or 696 or 697 for that matter.
This may happen if the port is configured as a trunk.
something like this:
set trunk 7/44 on dot1q VLAN numbers
one thing I don't know - if the show command output will be like the one you have posted.
05-16-2008 02:40 AM
Unfortunately yes!!!!
Here there in the show run for module 7.
05-16-2008 04:22 AM
Was module 7 hot-swapped into the chassis by any chance? If so, was there something different in slot 7 before?
Kevin Dorrell
Luxembourg
05-16-2008 06:31 AM
could you post the part of the config where 7/44 is involved?
05-16-2008 07:07 AM
Here it is
set port name 7/44 CREDEM_test
clear trunk 7/44 1-4094
set trunk 7/44 off dot1q
05-16-2008 07:08 AM
05-16-2008 07:10 AM
The module 7 is up from September 2007, the 14th.
It has never hotswapped out.
05-16-2008 04:40 PM
My question was more was it hotswapped in? That is, was the chassis already running when the module was inserted? I have had experience (on a 4506) where a card was hotswapped from one card type to different type, and the behavior was inconsistent until the next reload.
Also, have you noticed this 7/44 phenomenon only just now, or was it there since September?
Kevin Dorrell
Luxembourg
05-18-2008 11:27 PM
The meaning of my answer was that the module has been started contemporaneously with the chassis.
I work with that 6500 all the days and I've never noticed this strange phenomenon until a week ago.
Maurizio Gaigher
Italy
