Webcast-Catalyst9k
6500 modular ios to nonmodular upgrade
how can we upgrade 6500 non modular ios to normal 6500 ios?
1 ACCEPTED SOLUTION
there is particular procedure for ion to ios upgrade. it is the same procedure for ios upgrades
-Copy the image to the Active and standby Sup
-Configure an appropriate boot statement
-Make sure SSO redundancy is configured on both Sups
there is no issu upgrade for that
riccardo
Hall of Fame Super Gold
Download the non-modular IOS from Cisco website, copy the file into the supervisor sup-bootflash, change the boot string and reboot.
thanks for the answer, how about the vss? Is there any procedure to upgrade vss chasis for non-modular to modular upgrade?
You want to run modular IOS on a VSS?  Why?  Support for Modular IOS is nearing the end.
currently vss is running modular IOS. we want to change it to NON modular IOS. I want to make it with minimum interruption.
riccardo
1424
