6500 Multicast Error Message
TIM POTTICARY
We have started getting the following error code in our pair of 6513 core switches.
'error in multicast throttle logic'
The above error is being entered every few seconds.
We have recently changed from sparse mode to dense mode multicast due to an application that does seams not work correctly when running in sparse mode multicast.
Does anybody know what the above error message mean?
David Stanford
What version of code are you running on these switches?
Typically 'error in multicast
throttle logic', are cosmetic messages and were introduced as a result of a
previous code change.
There are a couple of internal bugs that have been filed to remove these
messages in the logs (CSCsk18102, CSCsl72962). The messages are
triggered under different conditions, such as when a route to a PIM RP
is learnt, when some flows are temporarily software switched with an RPF
change, or if a clear ip mroute * is issued.
The fix for removing these log messages will be in one of the versions
of SXI code which was released recently.
You can view details of CSCsl72962 below and track its status as well:
http://tools.cisco.com/Support/BugToolKit/action.do?hdnAction=searchBugs
Thanks for the info but unfortunately I get the following message when I try and access the bug reports on cisco.com
Information contained within bug ID CSCsl72962 is only available to Cisco employees.
