6500 police/rate-limit egress
I am trying to do an egress rate-limit on a 6500 Sup720/PFC3B 10/100 port. Everything I read seems to say it supports egress rate-limiting, but it will never let me bind a policy-map "output" on my interface. I am trying to rate-limit a 100Mbps interface to 10mbps/10Mbps. This is what I have so far. My ingress rate-limit seems to be working just fine. Any help would be greatly appreciated! Much Thanks....ahead of time.
access-list 100 remark QOS ACL For Rate-limiting Traffic
access-list 100 permit ip any any
class-map match-any limit_10Mb
description Rate-Limit 10Mb Ingress
match access-group 100
policy-map 10Mb_ingress
description Police 10Mbps Ingress
class limit_10Mb
police cir 10485500 bc 327671 be 327671 conform-action transmit exceed-action drop violate-action drop
interface FastEthernet4/29
switchport
switchport access vlan 136
switchport mode dot1q-tunnel
switchport nonegotiate
mtu 9216
no ip address
load-interval 30
l2protocol-tunnel cdp
no cdp enable
spanning-tree portfast
spanning-tree bpdufilter enable
service-policy input 10Mb_ingress
Re: 6500 police/rate-limit egress
Use.
Generic Traffic Shaping or Rate-limit (CAR)on the interface.
Best would be Generic Traffic Shaping.
http://www.cisco.com/en/US/docs/ios/12_2/qos/configuration/guide/qcfgts.html
CAR
http://www.cisco.com/en/US/docs/ios/11_1/feature/guide/CAR.html
Pravin
I apprecaite your help, but both GTS and CAR in the two links you sent me are for a layer3 interface.
I need to do egress rate limiting on a layer2 interface. Both the "rate-limit" and "traffic-shaping" commands are only allowed on a layer3 interface.
Do you happen to know somthing for layer2?
Thanks!
Sorry.
On layer 2 you can implement srr-queue
Its works a bit different:
Switch(config-if)# srr-queue bandwidth ?
limit -Configure bandwidth-limit for this interface
shape -Configure shaping on transmit queues
share -Configure shared bandwidth
below is the link for cisco 2690 switch.
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_44_se/configuration/guide/swqos.html#wp1163879
regards,
Pravin
Pravin,
I actually use the "srr-queue bandwidth" command currently on some of my 3560G switch's and it works fine, but my 6500's seem to only support Weighted Round-Robin queuing?
I an running ver 12.2(18)SXF8 on Sup720-3B's?
Do you know if I can do anything with egress rate-limiting and the "wrr-queue bandwidth" command, because it won't let me set a limit and seems to only let me specify a weight to queue ratio.
Thanks for your help!
4263
