6500 power considerations
Should I get 6500s with 6000w power supplies or less? What is the consideration in a server farm environment where there's no POE?
Blue
Re: 6500 power considerations
Fawad:
Salamat...
Some things to consider:
0.) What model 6500 chassis will you deploy?
1.) What cards will you populate the chassis with?
2.) How much power does each module consume and what is its current draw?
3.) How much current and power is each port on each module capable of delivering?
4.) Do you want to run an active/standby power supply paradigm or a load sharing active/active paradigm?
This should be a good start...
Victor
hi Victor,
we are deploying 6509-E switches with SUP720. They will have atleast 5x 6748 and 1x6704.
There is no PoE.
Fawad
Super Bronze
If you have access to it, the power calculator tool will show you power demand relative to different power supplies within the 6500 chassis.
Blue
Fawad:
The sup-720 consumes about 400W, depending on the model.
Allow about 400W for each 6704 module (you should probably order 2, not just 1, for module diversity for your uplinks).
I cant find the power consumption ratings for the 6748.
Do you have a Cisco sales rep? I am sure Cisco will be more than happy to help you order what you need. I dont see any need for the 6000W power supply, thats for sure.
Sorry I couldnt be more help.
Victor
Use power calculator -
http://tools.cisco.com/cpc/launch.jsp
You need to have CCO ID. If you don't have the access give me the hardware details I'll let you know the requirements.
>> Sushil
878
