ovt Bronze
Bronze
6500 service modules and Sup 32 compatibility question
Some of the service modules, such as WISM, WLAN, AON, AGM, ADM, etc. are currently not supported by the Sup 32 (Native IOS). Is this due to a some hardware limitation on just a limitation of the current software release?
Does Cisco have CEF720 service modules for the 6500 platform, or just CEF256 service modules?
Bronze
Re: 6500 service modules and Sup 32 compatibility question
WS-F6K-DFC, for use on dCEF256 and CEF256 modules with a Supervisor Engine 2.
WS-F6K-DFC3A, WS-F6K-DFC3B, WS-F6K-DFC3BXL, for use on dCEF256 and CEF256 modules with a Supervisor Engine 720.
WS-F6700-DFC3A, WS-F6700-DFC3B, WS-F6700-DFC3BXL, for use on CEF720 modules with a Supervisor Engine 720
Some are hardware/software limitations and some are a matter of testing with Sup32. May be in future releases they will be supported by Sup32.
HTH,
-amit singh
161
