Webcast-Catalyst9k
6500 Sup 720 3B broadcast/multlcast/unicast supression - Data plane
Hello!!,
We have a 6500 with Sup 720 3B. It is in truncated fabric mode. The requirement is that any Desktop/laptop/server that has been infected with any worms should not bring the vlan/network down.
The obvious solution would be to control broadcast/unicast/multicast packets. However since the chassis has classical line cards "storm control" and mls layer 2 rate limiters are not available. I am aware of the mls ARP policer. CoPP would be available for the control plane i.e for traffic meant for an IP on the RP.
My question is what is the best solution to control traffic (multicast/unicast) at the data plane. For example there is a user who is sending multicast packets to some random IP like 227.1.2.3 at full wire rate. How do we deal with this? I am assuming that CoPP cannot play any role here since 227.1.2.3 is no an IP that exists on the RP.
In my understanding correct? I tried/tested the below configuration, but still CPU goes up to 100%. Even if it works , by changing 1000000 in the policer to a smaller value, is the below recommended method to control excess traffic at the data plane, for hosts/servers connected directly to the chassis?
mls qos
access-list 2000 remark ACL_police_excess
access-list 2000 permit ip 192.168.202.0 0.0.0.255 any
class-map match-all class_500
match access-group 2000
policy-map VLAN_500_policy
  class class_500
     police aggregate POLICE_traffic_500
mls qos aggregate-policer POLICE_traffic_500 1000000 31250 31250 conform-action transmit exceed-action drop
int g2/3
description TEST
switchport
switchport access vlan 500
switchport mode access
load-interval 30
spanning-tree portfast
service-policy input VLAN_500_policy
CORE#show policy-map interface g2/3
GigabitEthernet2/3
  Service-policy input: VLAN_500_policy
    class-map: class_500 (match-all)
      Match: access-group 2000
      police aggregate POLICE_traffic_500 :
        1000000 bps 31000 limit 31000 extended limit
      Earl in slot 5 :
        193242226 bytes
        30 second offered rate 31875256 bps
        aggregate-forwarded 1527456 bytes action: transmit
        exceeded 191714770 bytes action: drop <---
        aggregate-forward 102576 bps exceed 13277944 bps
    Class-map: class-default (match-any)
      0 packets, 0 bytes
      30 second offered rate 0 bps, drop rate 0 bps
      Match: any
        0 packets, 0 bytes
        30 second rate 0 bps
PC in vlan 500 generates rouge multicast/unicast traffic.
Any help would be greatly appreciated!!
PS - I am using a small application called "wsend.exe" (Microsoft application) to generate multicasts.
Regards.
Everyone's tags (5)
393
