Community Member
6500 Switch Booting Probloem
One of my customer had a problem with A/C and the room tempreture reached almost 50 C. We came to the site and saved the configuration, took a abckup and shutdown the switch.
After the A/C problem is resolved, we tried to power-on the switch .. and we found that it is going to the rommon.
I put "boot" command to boot from the bootdisk, but I am getting the following error:
Initializing ATA monitor library...
loadprog: error - on read during ELF program load
requested 98504724 (0x5df1014) bytes, got -47 (0xffffffd1)
boot: cannot load "bootflash:s72033-ipservicesk9_wan-mz.122-33.SXI3.bin"
I tried to search it, But it is resulting in that most probably it is a hardware faliure on the SUP.
Any idea ?
Everyone's tags (4)
That guy had to reformat his sup-bootdisk.
Hall of Fame Super Gold
Something is not right with this statement.  Are you sure you put your IOS in this and not "sup-bootflash:"???
There can be a problem with sup-bootdisk or the IOS file itself. In ROMMON - try doing "DEV" command to see all memories you have.
If you have PCMCIA disk0/slot0 0 try to see if any image is there "dir disk0:" or "dir slot0:". And then try to boot it with "boot disk0:FILENAME".
You can take PCMCIA card from any other working switch - it is not impacting as long as that switch is booted. And then boot from that disk0 and the image on it.
Community Member
below is the output of dev command:
rommon 2 > dev
Devices in device table:
        id  name
bootdisk:  boot disk
    disk0:  PCMCIA Disk 0
    disk1:  PCMCIA Disk 1
    eprom:  eprom
      usb:  USB
I can not see sup-bootdisk, althoug in the secondary core switch which is typicall the same as the existing one has the image on the sup-bootdisk.
Is it possible to download the image on USB and try to boot from USB since I have this option ?
If I has to format the bootflash .. What are the procedures ?
Community Member
I tried to boot from USB, and it is givining me the below error:
rommon 1 > boot usb:s72033-ipservicesk9_wan-mz.122-33.SXI3.bin
Loading image, please wait ...
*** Open Error = -1
loadprog: error - on file open
boot: cannot load "usb:s72033-ipservicesk9_wan-mz.122-33.SXI3.bin"
What other option should I try ?
Re: 6500 Switch Booting Probloem
Hi Haytham,
Check if the image is checksum is correct and maybe try to download it again to be safe you got a working one. ELF errors are generally indicating incorrect file size.
Also, it would be a good to format a PCMCIA flash or usb under the same platform in case the current formatting is incompatible. And if still fails, there is a chance the DRAM has issues, so loading file to the DRAM from flash fails. This symptoms most often point to flash problems, though.
Kind Regards,
**Please grade this post if you find it useful.
Kind Regards, Ivan Shirshin **Please grade this post if you find it useful.
