6500 Switch Reloads to ROMMON Prompt
I have a 6509 switch that once rebooted goes to the rommon prompt and requires me to intervene in order to get the switch to boot.
As far as I can see the boot command is OK and the boot variable points towards a file that exists in the bootflash. Below are some excerpts from the config and the console as the switch is reloaded. If anyone has any ideas as to what is missing I would appreciate it.
I am trying to boot using the IOS file: s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin
The file is located on the internal sup-bootdisk
The supervisor is a SUP720-3B
A
CORE1#sh run
Building configuration...
Current configuration : 1961 bytes
! Last configuration change at 00:04:17 BST Fri Apr 14 2000
version 12.2
service counters max age 5
hostname CORE1
boot-start-marker
boot system flash sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin
boot-end-marker
spanning-tree mode pvst
diagnostic bootup level minimal
redundancy
main-cpu
  auto-sync running-config
mode sso
ip classless
ip forward-protocol nd
control-plane
CORE1#sh bootvar
BOOT variable = sup-bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin,1;
CONFIG_FILE variable does not exist
BOOTLDR variable does not exist
Standby not ready to show bootvar
CORE1#sh sup-bootflash:
-#- --length-- -----date/time------ path
1     33554432 Jan 31 2013 13:05:46 +00:00 sea_console.dat
2     33554432 Jan 31 2013 12:57:36 +00:00 sea_log.dat
3    100666828 Jan 31 2013 12:59:32 +00:00 s72033-ipservicesk9-mz.151-1.SY.bin
4            0 Jan 31 2013 13:05:08 +00:00 call-home
5    140062020 Apr 13 2000 02:43:44 +01:00 s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin
204218368 bytes available (307855360 bytes used)
CORE1#
CORE1#
CORE1#
CORE1#
CORE1#
CORE1#reload
System configuration has been modified. Save? [yes/no]: n
Proceed with reload? [confirm]
*Apr 13 23:05:38.531: %SYS-5-RELOAD: Reload requested by console. Reload Reason: Reload Command.
*Apr 13 23:05:41.535: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Apr 13 23:05:41.535: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*Apr 13 23:05:41.739: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
*Apr 13 23:05:44.327: %SYS-SP-3-LOGGER_FLUSHING: System pausing to ensure console debugging output.
*Apr 13 23:05:44.327: %SYS-SP-5-RELOAD: Reload requested by Delayed Reload. Reload Reason: Reload Command.
*Apr 13 23:05:44.327: %OIR-SP-6-CONSOLE: Changing console ownership to switch processor
*** --- SHUTDOWN NOW ---
*Apr 13 23:05:44.643: %SYS-SP-3-LOGGER_FLUSHED: System was paused for 00:00:00 to ensure console debugging output.
System Bootstrap, Version 8.5(4)
Copyright (c) 1994-2009 by cisco Systems, Inc.
Testing lower main memory - data equals address
Testing lower main memory - checkerboard
Testing lower main memory - inverse checkerboard
Clearing lower memory for cache initialization
Clearing bss
Clearing autoboot state machine
melody_present_reg: 1st read w/ 0x5555
melody_present_reg: 2nd read w/ 0xaaaa, reversed: 0x5555
Bootdisk adapter is detected, enabling bootdisk access...
Reprogramming CS1 w/ Melody value...
Reading monitor variables from NVRAM
Reset reason for CPU board 0xffff , BaseBoard 0x280ffff, display 0x20000System Reset by Software.
Enabling interrupts
Initializing TLB
Initializing cache
Initializing required TLB entries
SDRAM dimm
Initializing main memory
Sizing NVRAM
Initializing PCMCIA controller
Exiting init
Cat6k-Sup720/SP processor with 524288 Kbytes of main memory
rommon 1 > set
PS1=rommon ! >
SLOTCACHE=cards;
LOG_PREFIX_VERSION=1
BOOT=bootdisk:s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin,1;
?=0
NT_K=0:0:0:0
BSI=0
ACL_DENY=0
RANDOM_NUM=266681808
RET_2_RTS=00:05:43 BST Fri Apr 14 2000
RET_2_RCALTS=955667297
rommon 2 > dir bootflash:
Initializing ATA monitor library...
Directory of bootflash:
5250    100666828 -rw-     s72033-ipservicesk9-mz.151-1.SY.bin
20483    33554432  -rw-     sea_console.dat
4098    33554432  -rw-     sea_log.dat
20691    0         drw-     call-home
2      140062020 -rw-     s72033-ipservicesk9_wan-mz.122-33.SXJ6.bin
rommon 3 > dir bootdisk:
Directory of bootdisk:
rommon 6 >
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Andrew
It may be your configuration register that is the problem. If you do -
1) "sh bootvar"  this will show the configuration register on the RP. It will probably be 0x2102
2) "remote command switch show bootvar" this will show the configuration register on SP.
If 2) is not showing 0x2102 then do -
switch(config)# config-register 0x2102
then repeat 1) and 2) again to check they are both the same. No need to save config as the configuration register is not part of the running config.
Jon
Andrew
Jon
Hi Jon,
Problem solved. Thanks for your help
Andy
Hall of Fame Super Gold
I don't remember seeing this.
1357
