11-24-2010 07:06 AM - edited 03-06-2019 02:11 PM
Hi All,
I am just looking for some clarification regarding VSS...
I have read that with the latest code for 6500 VSS, I can use Dual SUP in each chassis. Can I use a 10gb port on each Sup for VSL? Is that supported? Or Do i need to use a port on a 10g card? Thanks.
11-24-2010 07:55 AM
You can use the 2 10Gig ports that comes with Sup-720-VS or a combination of one from the Sup and one from a line card.
Reza
11-24-2010 01:26 PM
Just to note that VSL is not supported on the 6704-10GE. I'm discouraging anyone to stay away from the 6708-10GE too because this blade won't be supported on the soon-to-be-released VS-Sup2T.
