6500 VSS Upgrade
Hi All
our  customer has a 6500 ( non E ) core switch with the following configuration:
  7    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL14491Z9C
  8    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL14491JCX
  9   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL14491CHW
10   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL14491C46
11   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL14491XRW
12    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1430NVNL
13    8  CEF720 8 port 10GE with DFC            WS-X6708-10GE      SAL1430NXA5
the customer wants to use will purchase a second Core switch-to use the two switches as a VSS pair-with the follwing config:
VS-S2T-10G (Q2)
WS-X6748-GE-TX (Q2)
WS-X6816-10G-2T (Q2)
We need to know what is the exact upgrade that is required on the first ( old ) core switch ?   appreciating your fast support.
MK
VIP Super Bronze
6500 VSS Upgrade
Hi Mohammed,
You need to upgrade fan try and power supply
Q. Will the Supervisor 720 be supported in all Cisco Catalyst 6500 Series chassis?
A. Yes. In the case of E-series chassis no fan upgrade is required. E-Chassis Fan tray is sufficient. In the case of non E-series chassis please follow the Table 2 for fan upgrade.
see table 2 in this link:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_qas09186a0080159963.html
6500 VSS Upgrade
Thank you Reza
the customer wats to upgrade the SUP on the old switch ( from VS-S720-10G  to  VS-S2T-10G ) shall we upgrade the line cards to suppor the new SUP and to run the VSS between the two swiches ?
MK
VIP Super Bronze
6500 VSS Upgrade
Yes, you would need to have the same type of line cards in both chassis if you want to do VSS.  If the old switch has a  VS-S720-10G installed and it is working then that chassis is already an E chasse.  There is no need to upgrade the chassis.  For VSS, make sure the line card models and the Sups are the same.
366
