6500 WS-X6704 -10GE ports cann't up at the same time
We connect two 6509 switches with 6704 10GE modules. However, we found 4 ports can not up at the same time. we checked the fiber links. GE sfp works well. Currently, the 6509s installed 1*6704, 1*6724-SFP,1*6748-GE-TX, 1*FWSM and 2*3000 AC power supplies.
Silver
Re: 6500 WS-X6704 -10GE ports cann't up at the same time
Do you mean the SFP signal shows the fibre link is up but the switch console shows they are down ? Is it the MM or SM fibre issue ? Can you post the "sh int" of those "down" interface ?
Check below info. for XENPAK :
http://www.cisco.com/en/US/products/hw/modules/ps5455/products_data_sheet09186a008007cd00.html
Compatiblity matrix :
http://www.cisco.com/univercd/cc/td/doc/product/gbic_sfp/10gbxcvr/ol_6974.pdf
Hope this helps.
Each 6704 10GE port can work well individually. However, they cannot up simultenously. Very stranger issue. We now use 12.2(18)SXF6 Advanced IP Services IOS.
Silver
IC, did you try to replace another module or plug it to other chassis ? Is there any fan tray 2 installed at the 6509 chassis ?
156
